balancer seating
Old Mar 21, 2011 | 05:39 AM
81blacktiez28's Avatar
Default balancer seating
how do you lock up a manual flywheel with the engine in the car. trying to seat a new balancer on an ls3 but cant get the crank to stop turning.
Old Mar 23, 2011 | 04:19 PM
redbird555's Avatar
if its a manual then you should just be able to put the car in 4th gear and put on the e-brake and tighten away
Old Mar 23, 2011 | 08:38 PM
S10xGN's Avatar
Another cheap way... Pull #1 spark plug, rotate the engine to the compression stroke, stuff some rope into the plug hole, gently rotate the engine (by hand!) until it stops. Do your work. Now, back the engine up a 1/4 turn, pull the rope, reinstall the plug and have at it.
Old Mar 25, 2011 | 02:15 PM
racecar's Avatar
4th gear, e brake, have a freind step on the brake pedal.
