ls3 intake bolts
Old Mar 22, 2011 | 11:24 PM
colorado808's Avatar
Default ls3 intake bolts
Can anyone confirm GM part # 12552344 is the correct number please. Seems pretty expensive for a GM bolt or if anyone knows of a set would be great.
thanks
Old Mar 23, 2011 | 01:24 PM
1lejohn's Avatar
I went the ARP stainless set # 430-2101 they cost 52.00
Old Mar 26, 2011 | 10:53 AM
ALLDUN5's Avatar
Here is what I found;
GM part #12552344 (M6 x 1 x 114).........................................$8.60 list ea
Fastenal part# 38581 (M6 x 1 x 120) zinc hex head....................$0.68 each
McMaster Carr #91280A368 (M6 x 1 x 110) zinc hex head............$3.79 for 10
McMaster Carr #91292A423 (M6 x 1 x 120) stainless socket head..$6.01 for 5
114mm = 4.488"
110mm = 4.331"
120mm = 4.724"
Old Mar 28, 2011 | 05:32 AM
tiresmokinV8's Avatar
I recently picked up 10 from fastenal using that part number. They worked fine as is. I just threw a washer under the head of each bolt since theres no flange or anything like the stock ones do.
Old Mar 28, 2011 | 01:43 PM
ALLDUN5's Avatar
I used the 120MM as well without an issue either.
Old Sep 6, 2011 | 03:21 PM
samckitt's Avatar
Funny, I too got the Fastenal 120mm long bolts & maybe 4 of them tighten up, the other 6 are too long. %$##$%^&*((&^%$!!!!!
Guess I gotta cut them shorter.
Old Sep 6, 2011 | 09:15 PM
00duvall's Avatar
go to hard ware store u can buy the same bolts for .96 cents. Just write down bolt size and thread u need.
Old Sep 6, 2011 | 10:38 PM
samckitt's Avatar
Longest I could find at any hardware store was like 70 mm long.
Old Sep 8, 2011 | 11:29 AM
Jim85IROC's Avatar
I wanted black bolts, so I went with ARP. The cost was about 1/2 the cost of new GM. As mentioned, generic m6 bolts are the cheapest route provided you can find the right length.
Old Nov 14, 2011 | 02:49 PM
chuckd71's Avatar
Good info guys, thanks for the part numbers.
