Need Help With PCV VAC Line
Old Apr 3, 2011 | 01:47 PM
Duntov1967's Avatar
Default Need Help With PCV VAC Line
I am in the finishing stages of my 402 and need help with the plumbing of the PCV lines. I have LS9 valve covers that have one port each. It is my understanding that these ports are for fresh air intake. I am running an L92 intake manifold that has a line coming from the top to the driver side valve cover. But I think this is a vacuum line and should not be connected to a fresh air port.
My valley cover is an LS6 which I understand has the PCV built-in so that port would be engine air out. So if someone could help me connect the dots, I would appreciate the help. Here are some pictures:
Old Apr 3, 2011 | 06:10 PM
Duntov1967's Avatar
After thinking about it more, I am considering this configuration. Any thoughts?
Old Apr 4, 2011 | 07:51 PM
Duntov1967's Avatar
Anyone?
Old Apr 4, 2011 | 08:07 PM
TransWS6Am's Avatar
Old Apr 4, 2011 | 08:09 PM
TransWS6Am's Avatar
This is pretty much correct except you dont run the line over to the passenger side cover, just cap the passenger side off.
Old Apr 5, 2011 | 06:25 PM
Duntov1967's Avatar
Thanks!
Old Apr 5, 2011 | 07:48 PM
Gordon0652's Avatar
What coolant crossover are you running? Where is the outlet to TB from the crossover going to?
Old Apr 5, 2011 | 08:35 PM
Duntov1967's Avatar
The coolant crossover is from a '99 LS1. The line will bypass the throttle body and run to the stock location on the radiator.
