ls3 heads on an ls1?
Old Apr 8, 2011 | 04:08 AM
BlueMagicSS's Avatar
Default ls3 heads on an ls1?
I was looking for more info about ls3 heads on an ls1.... what all needs to be done? I know the intake would have to be changed as well... what else? thanks for your help.
Matt
Old Apr 8, 2011 | 04:40 AM
LS1MCSS's Avatar
You can't put LS3 heads on a LS1 that has the stock bore. I believe the exhaust valve hits the top of the cylinder.
Old Apr 8, 2011 | 07:49 AM
87silverbullet's Avatar
^^^What he said. You need a minimum 4" bore for LS3 heads. Your bore is 3.898
Old Apr 18, 2011 | 06:02 PM
4doortypels's Avatar
mast motorsports makes small bore ls3 heads for ls1/6 apps... http://www.mastmotorsports.com/2010/...p?cat=Cylinder Heads - Assembled&id=360
Old Jun 25, 2011 | 02:43 PM
slowlsx's Avatar
^^^ booya! Just saw these today
Old Jun 30, 2011 | 12:28 PM
sscamaroburn02's Avatar
has anyone run these heads on here. I'd like to see some #'s if possible.
Old Jul 25, 2011 | 11:54 AM
i6overboard's Avatar
^^^Im interested in this as well, someone had said there was a thread in dynamometer section but I couldnt find anything.
Anyone have some more info on them?
Old Jul 25, 2011 | 12:46 PM
x2 as well
Old Jul 25, 2011 | 02:14 PM
DaFireMan's Avatar
just call mast an see if they have any results on that, or dyno graphs. im also interested in they numbers as well
