Oil cooler to Ls3 with tight exhaust manifold fittings.
Any hints how to do do it.
![](http://static.summitracing.com/global/images/prod/large/ctr-22-595_w.jpg)
This kind of adapter didnīt fit, no room for pipes. there is less than inch from filter to exhaust.
![](http://static.summitracing.com/global/images/prod/large/ham-3323.jpg)
This kind dont work too good either, pipes go too low (for ground clearance) so would need to be connected with 90degree fittings, then those are also pretty wide and it gets tight with exhaust again.
So, hints? And remember, LS3 so M22x1,5mm thread for filter...
