Milling L92 question's
my local speed shop said around 20thou? sound about rite?
my cam is a 226/234/.602 and my pushrod length is 7.425
"Rick,
I wouldn't mill too much...maybe .010". P to V is tight with no valve
reliefs.
Geoff"
i have decided not to cut in the future i might do a 408 untill then there going to stay stock.
My LS6 style heads have 53cc chambers and I run like 12.2:1 static and 8.5 dynamic. In the past, the ET Heads people offered chambers as small as 35cc I believe.
With this I am not including the issue of deck thickness or warping because it was mentioned, but not considered a factor for a N/A engine without extreme compression. I have had no head gasket/sealing issues. P/V clearance and push rod length should also be ignored for argument. They are adjusted and fine.
I'm just throwing this in the mix for conversation.
Thanks!
Because of my setup and to get the CR that I want I need a larger chamber. If I go the other route and dish the pistons to get the desired CR, that would make them to thin and top ring land to weak.
I think the 'cylinder area' might be just the problem. On an L92 engine the bore is actually smaller than the chamber in the head. The bore itself shrouds the valve. Cutting the head makes things worse because the valve now goes deeper into the bore.
