Ls1 Valve Covers on LS3 heads.
Old May 31, 2011 | 03:49 PM
ultradriver10000's Avatar
Default Ls1 Valve Covers on LS3 heads.
Ok, I didn't want to spend $300+ on valve covers that don't help performance in any way so this is what I did. I have LS3 heads on my 416 with LS1 covers and LS1 valve cover bolts. (They are like $4 brand new from the dealer.) My rubbers broke.
Stupid oil baffle.
Come off!
Now to get off those rivet style studs.
Bitches
Getting there
Grind time
The one on the right is about 75% ground down. The one on the left is factory.
Pile of aluminum
Covers all done.
High Temp Semi Gloss Paint. I was going to go with some crazy color but decided to go with the classic black. I think I'll try to make everything in the engine bay a nice semi gloss black. The paint isn't the smoothest, but I wasn't really going for show quality, just a clean look.
Not too shabby looking.
Success
LS1 Valve Cover Bolts - Part Number 12577215 $4.42 Dealer price, $2.59 GM parts direct.
Old May 31, 2011 | 04:36 PM
Austin Auflick's Avatar
exactly what I did. Feels good huh?!
Old May 31, 2011 | 05:00 PM
Yes sir! I see more and more people asking so I figured I'd post pictures up. Only took me about 30min of real work, maybe 1 hour after painting.
I just can't see spending all sorts of money on aftermarket valve covers.
Old May 31, 2011 | 05:19 PM
OutKlast's Avatar
Indeed. I see some machine them out of a solid block of high grade aluminum... what the hell man? The things a damn cover that keeps crap out of the engine and the oil in. I don't think I've ever seen a post where someone said, "Oh man... engine just blew up... damn these faulty valve covers!"
Old May 31, 2011 | 05:23 PM
I don't mind nice anything. I just have priorities. Forged rotating assy, iron block, AI LS3 heads, Nitrous outlet DP...
Old Jun 2, 2011 | 02:23 PM
BrntWS6's Avatar
Sucks when your rubbers break.
Old Jun 2, 2011 | 03:31 PM
1A Dan's Avatar
I had to do something very similar to the covers I got off my 5.3L. baffles were a little different and cast, so dremel had to be used (along with about 3 dozen cut off wheels). nice to mod something yourself and save a ton of loot. glad to see someone did a writeup!
Old Jun 2, 2011 | 03:45 PM
'02TA's Avatar
Old Jun 3, 2011 | 01:03 AM
cornerburner's Avatar
Looks great! How was it getting the 4 main bolts out, and back in? I'm about to do the same with my valve covers and I'm trying to decide on preserving those bolts and rubber or replacing them.
Old Jun 3, 2011 | 12:11 PM
The rubber on all my valve cover bolts ripped off. I purchased 8 new ones from the dealer at about $4.25 each. Mine were original equipment on my 1997 C5 so they were pretty old/dry rotted. Try rubbing some oil on them before you pull them out so they don't rip. I'll get the part number when I get home.
Agreed, lol. Glad someone caught that one.
Old Jun 4, 2011 | 01:40 AM
[QUOTE=ultradriver10000;14994834]The rubber on all my valve cover bolts ripped off. I purchased 8 new ones from the dealer at about $4.25 each. Mine were original equipment on my 1997 C5 so they were pretty old/dry rotted. Try rubbing some oil on them before you pull them out so they don't rip. I'll get the part number when I get home.
Cool, the part number would be helpful. Are the bolt/rubber sold together, or just the rubber seals individually? Another thing, did you remove the baffling and clearance the inside of the valve covers for rocker arm clearance? I am curious if you or anyone for that matter has had any interference issues using the stock valve covers. I would imagine that there could be clearance issues with aftermarket rockers, but I am asking more specifically about a stock rocker arm setup with a high lift cam. I'm not quite at the stage in my build to check for this fitment, but I sure wouldn't mind knowing ahead of time
Old Jun 4, 2011 | 09:36 PM
Billiumss's Avatar
I ran into the same problem with my LS3 build for my 2001 Camaro. I ended up buying some brand new LS3 valve covers from SMC performance for $90.00
Old Jun 4, 2011 | 10:05 PM
Gregory's Avatar
ultradriver10000:
Is that an air powered belt sander in the picture? Those things are so cool. In the past I have used air powered belt sanders for commerical die grinding.
- Greg
Grind time
Old Jun 6, 2011 | 08:03 AM
I updated the part number for the valve cover bolts. They come as a complete assembly with bolts, sleeves and rubber seals.
Yes it is an air powered belt sander. This little tool rocks socks! It helps modify a lot of parts.
Old Jun 6, 2011 | 12:15 PM
OutKlast's Avatar
I clearanced my valve covers yesterday. I had actually turned the engine on briefly when I first put it together so I saw where it was hitting. The only spot I'm really worried about is by the drivers side PCV vent. The cover is indented there so you can't really cut that out.
BTW, you can buy FelPro grommets and valve cover gaskets by themselves.
Part numbers should be:
ES72233 - Grommets (Full set of 8)
VS50504R - Gaskets (Pair of 2)
Autozone has them, I found them at a local auto parts place because the autozone by me doesn't stock the grommets, they have to be ordered.
Cost is around $28-35 with tax for the grommets+gaskets.
Old Jun 6, 2011 | 01:56 PM
Dang! Wish I would have known that!!!
Old Jun 7, 2011 | 02:15 PM
OutKlast's Avatar
Curse you small valvecovers. Put it back together today, its hitting on the drivers side still. I bet its that damn PCV vent area.
Unfortunately, Hinson is out of the thicker valve cover gasket until July otherwise I would have went that route.
Old Jun 8, 2011 | 12:49 AM
Thanks for the part numbers. Also, the pictures of your engine made me firmly decide that I'm going paint the valve covers on my 416 black as well, looks great!
Old Jun 8, 2011 | 08:38 AM
Put some liquid white out on the rockers and rotate it by hand. See where the white out is on the cover and start grinding!!!
Thanks man! Glad I could help. I know a lot of guys will be doing this so I figured I'd post up all the info I could.
Old Jun 8, 2011 | 05:56 PM
OutKlast's Avatar
Had a similar idea, tried it out today. Miserable failure. It seems that without operational pressure to the hydraulic lifters you lose lift. The consequence... none of the rockers hit when turning over the engine by hand or starter. Only when running and providing consistent operational oil pressure.
