need info on engine bay oil pressure gauge
Old 05-31-2011 | 05:39 PM
mondols1's Avatar
Default need info on engine bay oil pressure gauge
i have an 02' f-body that has been reading low for years. i would like to hook up a mechanical oil pressure gauge in the engine bay right above the oil filter to see what the true pressure reading is before changing out the sending unit. does anyone sell a kit for this or know what fitting size i would need to hook into the block above the oil filter?
Old 05-31-2011 | 08:21 PM
S10xGN's Avatar
I mounted one there for my initial fire-up. It's in a C5 "block" that has the port (temp sender?) in it, but I did have to re-drill & tap to a pipe size. Can't remember if it was 1/8" or 1/4" though. Mine cleared everything by inches, so I left it in place for good.
Old 06-01-2011 | 12:28 AM
mondols1's Avatar
tks, meant to post under gen III
