LS1 MAP on LS3 intake?
Old Jun 18, 2011 | 02:15 PM
Droptoplt1ta's Avatar
Question LS1 MAP on LS3 intake?
Is there a way to use a LS1 MAP sensor on an LS3 intake?
Thanks
Old Jun 18, 2011 | 03:18 PM
colorado808's Avatar
Thanks
I made a bracket to screw down the map sensor. I couldn't find a good enough fit for a o ring so I just used RTV to ensure a good seal. I haven't ran it yet but I know it will have a tight seal.
Old Jun 18, 2011 | 07:45 PM
Austin Auflick's Avatar
I just RTV'd mine. Works great.
Old Jun 18, 2011 | 08:50 PM
Irish350's Avatar
same type of setup
Old Jun 26, 2011 | 05:25 PM
Specialized's Avatar
Does anyone have some dimensions for this adaption? Maybe I could make these... Ideas...
Old Jun 26, 2011 | 06:51 PM
L-EATER's Avatar
11 Second Truck Club
A short section of 1/4" rubber fuel line works perfect as a grommet.
Old Dec 12, 2011 | 06:01 AM
chuckd71's Avatar
What are you guys doing with that black ribbed hose coming out beneath the map? Would it work if I put my map on the end of that? I think the map in it's proper location will be in the way of my throttle and tv cable bracket.
Old Jun 4, 2013 | 11:19 AM
RX-Ben's Avatar
I know this is an old thread, but I looked at it when doing my swap.
There is an easier and better solution that making a bracket and finding an o-ring to make the LS1 sensor fit on the LS3 manifold - tap the threads on the LS3 manifold with a pipe tap (I don't have the size handy, but I think it was 1/4") - it is perfectly sized to simply turn the tap, no drilling needed. There is plenty of material on the intake to securely hold a barbed pipe fitting.
On the LS1 MAP sensor - take off the rubber ribbed fitting and plug in a 5/16" hose (I think) - MAP sensor has a barb that will secure the hose.
Connect the sensor and the barb with rubber hose and secure the sensor in a sensible location.
This takes all of 5 minutes once you have the parts and you will not have to worry about leaks.
 Michael S. Palmer
Old Aug 27, 2013 | 11:50 AM
mchicia1's Avatar
You can just get a rubber stopper from sears, drill a tiny hole through it, and shove the map sensor in there. It will be a tight fit. Can silicone it in if you want.
Then just extend the harness or buy the casper extension.
Old Sep 16, 2013 | 04:02 PM
mklaus1's Avatar
So are you saying you would have a length of tubing between the actual sensor and the intake manifold brass barb? I am just trying to picture what you are describing, I think I understand.
Old Sep 16, 2013 | 04:07 PM
RX-Ben's Avatar
That is correct, and now you can located the MAP sensor wherever you want (within reason).
