Mast motorsports LY6 not going to WOT
I have an LY6 with a mast motorsports harness and controler . I discovered the problem when I installed a NX kit with a tps WOT switch . The switch would only work with manual movment of the throttle blade . After hooking up the laptop I find the pedal will only go to 93% . I removed the pedal from the floor and there is no interferance . I tried to change the FPP1 & FPP2 voltage configuration but the program will not seam to let me change it . Any ideas ??
