oil pressure sending unit
Old Aug 2, 2011 | 12:44 PM
BRD-PREY's Avatar
Default oil pressure sending unit
I have the long(tall) 1 wire oil pressure sending unit for the F-body now. I'm swapping a LS3 block in and it has the pedestal on the valley cover for the pressure sending unit. This leads me to believe I need the shorter one. The only shorter I have found have 3 wires. Does anyone know the correct number oil pressure sending unit part number I need?
Thanks
Ed
Old Aug 3, 2011 | 06:27 PM
BRD-PREY's Avatar
Default LS3 into F-body
So no one who put an LS3 into a F-body even noticed what I'm talking about?
Old Aug 4, 2011 | 01:09 AM
kevin kuether's Avatar
You can use the long sensor. I have an lsx block with the same valley cover and I used the long one. My fast 102 intake sits higher than the sender with the pigtail attached.
Old Aug 4, 2011 | 05:35 AM
davidws6's Avatar
If you use the FAST, be sure and check clearance with the tall sensor.
The FAST on mine was pushing against it and cracked it. Upon disassembly the sensor fell apart. Nothing a little filing on the back of the intake would not fix.
Old Aug 4, 2011 | 07:05 AM
BRD-PREY's Avatar
thanks for the responses
ed
Old Aug 6, 2011 | 11:39 PM
litle88's Avatar
I'll be installing an Ls3 in my fbody as well with a fast 102, which sensor do I need? I dont want to hack up 850 dollars on an intake! Don't mean to highjack! Sorry
Old Aug 7, 2011 | 09:32 PM
S10xGN's Avatar
I've got a late-style valley cover out in the shop somewhere... IIRC, the "tower" had enough meat to be cut down and rethreaded to make it lower. Also there was a thread here a few months back on using a 90° angle adapter fitting to get the OP sensor out of the way.
Old Aug 10, 2011 | 10:44 PM
60fthnter's Avatar
Do you know if cutting down will make it work or fit better?
I tried to go to O'Reileys to get a 90* fitting and the guy was an idiot. I swear all they ask those counter people if they know what an oil filter is and if they can use a computer!
Old Aug 11, 2011 | 07:21 PM
S10xGN's Avatar
Without seeing what you have, I couldn't venture a guess. Look here, down towards the bottom is a parts list.
Old Aug 12, 2011 | 06:38 AM
bonethugluv's Avatar
Brd-prey. You can use the stock ls1 oil pressure sensor I did. Plenty of room under with the ls3.
Old Aug 14, 2011 | 10:09 AM
60fthnter's Avatar
The issue come in when running a fast 102mm intake. I had to radius the intake right were the oil pressure sending unit sat to make sure they weren't touching.
