True dual LS2 402ci exhaust size?
LS2 402, its 11.7:1, PRC stg 2.5 l92's, stock ls3 intake, PTM 92mm TB, Pat g cam, M6, moser 9" with 4.10's 28" tires. 554/510 hp/tq at the rear wheels. Your converter will probably eat quite a bit of power from you car so dont get stuck on dyno numbers. Depending on your cars weight, low 10's will be a cake walk. if you're sub 3k lbs and have a good suspension setup i'm sure it could POSSIBLE do a 9.9x in good weather.
Maybe I will just wait until tuesday and see if TSP can change it to fit with a th350. Are you guys 100% sure that 3" nascar flat pipe has the same amount of flow as round pipe 2.5"?
The maximum cross section you can have for any givien diameter pipe occurs when it is perfectly round. If you "crush" 3-inch pipe such that it is still 3 inches on two sides then it can only be 1.75 inches on the other two sides. The cross sectional area of a 3" X 1.75' rectangle is 5.25 square inches. The cross section of a round 2.5-inch pipe is 4.91 inches (only 6% less) while the cross section of a 3-inch pipe is 7.07 square inches (about 35% more that the flattened rectangle).
I am. Although, comparing flow rates for different pipe sizes requires an exponental calculation, this problem can be resolved using simple cross sectional comparison.
Pipe bending that reduces the cross section of pipe can serve to reduce flow capacity. Pipe bending that maintains the cross section of the pipe - mandrel bending - does not reduce the flow capacity enought to matter. It may be easier to maintain cross sectional area with flattened pipes, but as already discussed - for any given size the flattened pipes, before any bends, start out with reduced flow capacity.
Agreed so if TSP can build a set to fit my car then this is the way to proceed. If not then I will have to move forward with the flat piping as this would be the best route for me. There aren't any shops around here that have a manderal bender unless anyone from New Orleans know a place.
There was a guy local to me and a good friend that did exhaust and he was the best. He ended up getting picked up by an exhaust company to teach how to do exhaust work. He was so good that he ended up on the show West Coast Customs and was doing a custom exhaust on a Magnum wagon. Its hard to get ahold of him now but if he was still doing it down here I would definitely send you to him.
I think Supreme Muffler in Metairie can do a mandrel bend.
The worry is the X-pipe won't fit past the transmission cross member. My crossmember is different than a 4L60E. IT comes futher down and goes longer towards the rear end. That's wear the toqure arm ties into it. Here is a link of a picture of the one I have on my car.
http://www.lmperformance.com/image.asp?p=tcc018&m=2
this is my t-56 x-member, it is also a BMR piece, and my TD's have a crap ton of extra space between that and the x pipe, and they are both designed to fit a stock length tq arm, so like i said, it shouldnt be an issue with your th-350 swap. http://bmrsuspension.com/siteart/pro...C006_large.jpg
#34
In any event, a flattened (rectangular shaped) pipe with two 3.5-inch sides and two 2.75-inch sides would have a flow capacity that is approximately equal to round 3 inch pipe.
#35
I am not sure I understand how this works. Specifically, a flattened pipe with two 3.5-inch sides and two 2.75-inch sides would have a circumference of about 12.5 inches. If you convert that shape into a round shape, also with a 12.5 inch circumference, it would be almost 4-inch round pipe rather than a 3-inch pipe. Perhaps, 3-inch round pipe results because the pipe machine installs a "fold" for strength or simply to use up the extra metal.
