ls3 edelbrock vic jr. fast 102mm tb and elbow vs 4 hole tb
how much more power do yall think the dry throttle body w port injection is worth over my fast EZ setup with the injectors in the tb? i know one advantage of a carb is the cooling effect of the fuel in the intake charge which a wet TB would give, but would the tuning advantage of port injection overcome that.
(1) EDL-9127 PLG PIPE 3/8 IN $2.95
(1) FST-54027 FUEL PRESSURE GAUGE KIT $39.95
(1) SUM-220652B -06X3/8 90 JIC-NPT W/FNSH $9.25
(1) SUM-220846B 8AN TO 3/8 NPT ADAPTER W/FNSH $2.95
(1) SUM-220856B -8 3/8" NPT ADAPTER W/PORT BLK $8.99
(2) SUM-220887B -8 90 DEGREE BLACK HOSE END $29.90
(1) EDL-3638 Edelbrock Aluminum Fuel Rails
If you don't want the Fast Fuel Pressure gauge then dont buy (FST-54027 or SUM-220856B) and buy (2) of the SUM-220846B
I bought the Black braided fuel line off ebay...
Matt
Matt
