Should I get a custom Marcella sheet metal intake?????
I spoke to him (email) and I'm considering getting one, $1,000 down and wait like 26 weeks for it. I can use a FAST 102mm in the meantime, then retune for the Marcella and the spray when its delivered.
Money is meaningless.....but I don;t want to spend it if it'll just be a waste of cash........so......
Question is: Is it going to make allot more power than a ported FAST 102mm.
441ci (4.125 x 4.125)
WCCH ported Brodix LS7 heads
Marcella intake: with a 102mm TB (or maybe larger)
Much more aggressive cam than in my sig
11.5:1 cr (93 0ctane)
4L80E
3.23 gears
3200 stall
200-250 DP shot plumbed into the intake, stand alone tank with race gas
******Roll racer only. Street car only. Never a drag racer.*******
4L80E
3.23 gears
3200 stall
I'm not so concerned with low end, off-the-line starts, as I'll be on radials anyway and on the street. Only so much power and torque can be put to use on the street...from a dig. I'll have way more than would be useful. At a prepped track on slicks I could see this being an issue.
Why go Marcella? This intake looks perfectly functional
https://ls1tech.com/forums/generatio...take-ever.html
That thing is garbage...............lol
I'm sure you've spoke with John regarding runner length? I was going with one of his intakes (through VSpeed) before we figured the tbody configuration wasnt going to work. With all the power in my build intended for 6500-6800 and below, low end really wasnt going to be an issue.
He can pack 10lbs in a 5lb bag if you know what I mean![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![](http://i179.photobucket.com/albums/w291/lpe403/Project%20Parts/marcella3.jpg)
Depends on where your power band is no matter what the use. If it's a higher strung engine and you hit it at 40 and get little to no flash out of the converter you will be lugging down on the shift. The purpose of a higher stall converter is to help get the motor in it's power band quicker. If this car shifts at 6500 or better (should be 7k) he will never lose more than 1500 on the shift so in a roll race he won't be below 5krpms ever. If he is going to spray it then I would say yes a tighter converter would be much better.
So what would you recommend for a 250 shot on top of the 441ci?
I'll experiment........I can buy two different converters and try them out.
What two? And I think my builder actually wants me shifting at 6700 rpm. IIRC.....
Question about the sheet metal intakes under the cowl of a Firebird T/A.
I don't want to cut anything.....Marcella said he'll make it fit perfectly.
But....will it have an issue with the rear cylinders getting starved a little bit of air, as compared to the forward cylinders?
The cowling on a Firebird is rather low and he mentioned to me that to make it fit would be the main deciding factor in the intakes design......where as if he had unlimited room he can put 100% of his techniques towards making the best intake for the engine......
I was just wondering if the design requirements will make the rear cylinders have issues......like almost every other "plastic" type intake does.
Oh man......I never for a second thought John would just sell me something just to make a sale.
