L92 swap
Old Feb 15, 2012 | 01:01 PM
Jarrah's Avatar
Exclamation L92 swap
Dear everyone,
I have a 2010 silverado 6speed auto, It's 5.3l I am swapping the engine with 6.2l, however I will run 243 heads with comp 228/240 113 lsa cam, 7.4 comp pushrods, trick flow dual spring, custom headers and Volant air intake , please advise me with this setup.
Is it better to run l92 heads or 243 or ls7 heads keeping in mind I have the 243's from my previous engine.
Old Feb 15, 2012 | 01:19 PM
Prorac1's Avatar
Are you buying the 6.2 as a long block or a short block?
Old Feb 15, 2012 | 01:37 PM
Jarrah's Avatar
Short block from 2010 escalade
Old Feb 16, 2012 | 01:05 AM
Jarrah's Avatar
guys no reply please i need you help my truck is in the garage i need to take a decision on this, should i run the 243 heads or not.
Old Feb 16, 2012 | 02:10 AM
93Z2871805's Avatar
Veteran: Air Force
What are you doing with this setup? Street truck? Drag setup? High stall and deep gears? VVT or not?
Old Feb 17, 2012 | 02:02 AM
Jarrah's Avatar
This is a street setup, currently no gears or TC, vvt has been canceled
Old Feb 17, 2012 | 04:49 AM
ls1ya's Avatar
Keep the l92 heads and get a f.a.s.t or ported ls3 manifold
Old Feb 17, 2012 | 06:38 AM
Jarrah's Avatar
Wat would be the impact if I run 243 heads, I will have higher compression.
Old Feb 17, 2012 | 07:30 AM
BMF_Racing's Avatar
Cool
243's will raise comp ratio, but only slightly. Also that gain will not out weigh the loss of CFM flow you would have going from L92's to 243's. If you don't have either of the heads now, then I say go for the L92's (over 300 cfm in stock form), you will make more power.
http://sdparts.com/details/12629063
If you already have the 243's then go for it, they will be fine.
Good Luck.
Old Feb 17, 2012 | 02:30 PM
K11PER's Avatar
Go L92 head/Ls3 intake or Fast intake if you got the money
Old Feb 17, 2012 | 07:08 PM
Bo185's Avatar
Your 5.3L already has 243/799 heads you could reuse those and upgrade to the hollow valves. Why buy new 243 when you already ahve them?
Then why run 243's when you can get new L92/LS3's for $320 bucks assy. new??? From another place than the one posted.
