Ls2 403ci w/ l92 build
I just pulled my motor in my 02 z28 which has about 100k miles on it and im starting to build my new motor... So far i have my top end for the new motor... TEA ported L92's w/ a port matched ls3 intake, eps stroker cam, prc .675 springs, ls7 lifters, and most of the other basic parts....
The next purchase is gonna be the block with callies compstar crank, H beam rods, and wiseco -8cc pistons which will be coming in a couple weeks.... This is the first build ive ever done so if anyone wants to comment please feel free all the help in appreciated!!
I have the pics but ive been very lazy since pulling the motor lol but ill have them up later tn!!!
we'll see ... Im going from my stock ls1 to this beast so i should be satisfied for a few months! Trending Topics
we'll see ... Im going from my stock ls1 to this beast so i should be satisfied for a few months!The Best V8 Stories One Small Block at Time
One thing to remember is a small cam will work! I ran 3 different cams in my motor the smallest one produced the most hp & Tq. I did have a one cam that was the same in HP but didn't have nearly the same tq that the smaller one provided.
FTI has been doing my stuff for years. Have no dyno # but it works at the track
Matched parts will always work better than any one special one
Tim
Cam #2 243/255 114 LSA 495/453 on a mustang dyno (Car picked up MPH & E.T over cam #1)
Cam #3 239/247 111 LSA 495/505 on same mustang dyno as cam #2 ( Track results TBA ) This cam was spec'd to get more street fun and get it moving off the line since it's usually about 3850-3900 raceweight.
Give Geoff a call and see what he spec's for your setup. Be honest about what you want out of it and plan to do with the car and I'm sure he will set you up with something good.
By the way, don't forget about a Tick MC/Bleeder setup for that new clutch. You will need it. Also be thinking about a rearend ... it appears you may have the stock 100k mile 10-bolt under there.
$505 shipped on a Level 4 monster clutch with light weight flywheel and new slave :0000
