LS2 FAST 102 Before Longtubes
he gained 21hp and 20ftlbs thru stock manifolds and smaller cam...WITHOUT A TUNE. no reason the OP shouldnt see the same.
How is 15hp for $800 is the same hp:$ ratio as 25hp for $500?
Even if you buy more expensive headers, 25hp for $800 is still better ratio than 15hp for $800.
Sorry, your not convincing anyone of anything here.
Don't think the other person gaining that much is convincing anyone either. Because the whole world of modding LS engines would be upside down as noone would EVER do headers as their first mod when a FAST intake that is 10x easier to install gains as much power.
Your the one who is refusing to believe the evidence.
Well I saw a stock 4th gen 6 banger with a fast intake duct taped to the 3.8 put john force on the trailer...that don't make it true now does it?
Side note, got a friend who doesnt post on forums, but running a full exhaust 05 gto. Hes considering doing the 102 as well, stock tb, rails and injectors. If he does Ill be sure to post results in here.
Also like others have mentioned, 1 person doing it isn't exactly "evidence".
Why is that one person swapping manifolds and gaining 20hp evidence, but my buddy doing the same swap and gaining 6 not? I posted a result I observed, someone else posted a result they observed. But mine is not "evidence" while his is...
You value your single "my friend and I" dyno over a commonly held theory backed up with numerous dynos. What's more likely, that your dyno test was right or that all these dynos tests were wrong or that your single anomaly? It is the equivalent of denying gravity exists because you and your friend saw someone levitate at a magic show.
21 hp, 29tq HERE on an LS2 With Bolt ons.
23hp/25tq HERE with 102 TB over an ls2 Intake.
35 hp HERE with a retune over an LS6 intake on cam only ls1.
32hp and 35 ft lbs HERE with injectors on a cammed ls2.
42hp and 36 Tq from FAST with portingHERE before a tune, over stock ls2 intake on a H/C motor.
The LS2 Intake is a POS and the FAST will make lots of power on an LS2, end of story.
You value your single "my friend and I" dyno over a commonly held theory backed up with numerous dynos. What's more likely, that your dyno test was wrong or that all these dynos tests were wrong and yours was the only one we should listen too? It is the equivalent of denying gravity because you and your friend saw someone levitate at a magic show.
You have shown me results tuned on bolt on and cammed cars. Other mods, especially headers, heads and cam will make a huge difference in how a fast manifold will react. So seeing how the average of a tuned car with cam is between 25-35rwhp I don't see how you can expect a 20rwhp gain on a car with no headers, cam or heads.
Go on ls1gto and post this same question, what mod should be next and I guarantee you a majority of people will say headers.
And idk if I'd want to spend $1500 on a bunch of pipes. There are high quality headers to be had for under 1k, I got my kooks headers and cats for $775 and pick up 27rwhp throughout the curve unlike a FAST which will most likely lose power under 5k and only make more power after.
You have shown me results tuned on bolt on and cammed cars. Other mods, especially headers, heads and cam will make a huge difference in how a fast manifold will react. So seeing how the average of a tuned car with cam is between 20-30rwhp I don't see how you can expect a 20rwhp gain on a car with no headers, cam or heads.
Besides, thats like arguing that I won't see significant gains from a cam unless I do headers first... The fact is the Ls2 is heavily restricted on both the intake and exhaust manifold.
He is the only datapoint, based on that and the other gains I would say yes its safe to assume you would get 20whp from a fast on manifolds.
That's true that it is, but there's a reason that for the past 15 years that the Gen III/IV has been out that 95% of the time people recommend headers as the first mod. So all these years we were all doing it wrong when a simple intake manifold is the better way to go?
Actually people have been swapping to LS6 intakes for a long time. Also the LS2 intake was a step backwards from the ls1 and only made for a few years.
I see your thought process here. But before you go crazy with things, think your entire process through. Porting the FAST will do nothing for your mild bolt on car. You are not going to see the typical gains associated with header equipped cars, because you have now only solved half of the equation. A FAST requires a retune. Headers you can go a few months without retuning. Buy cheaper headers and do it yourself if you're pinching pennies to mod. cramming air is not nearly as effective if you can't get it out.
I agree that the FAST is an awesome piece, I have one. But I completely agree with the folks that are trying to get you to see this from a little bit larger field of view.
But I'm about to call Maryland Speed and order the FAST and some stepped Kooks so I guess we will never find out.
http://speed-eng.com/store/fast-lsxr...79c92bcaa652e1
Waiting for results!
