Valley Cover need bigger Outlet?!
Old May 14, 2012 | 09:07 PM
1999FirehawkLS1's Avatar
Default Valley Cover need bigger Outlet?!
Building a 11.4:1, 427NA LS7 Top End, Street/Strip Car.....wondering if the factory 3/8 nipple on the ls6 style valley cover is going to be enough?
Does anyone make or have suggestion on moding the cover for a -8na outlet
Cover has the built in baffle box on the under side...thx
Old May 14, 2012 | 10:07 PM
Gray86hatch's Avatar
Welded a -12 in mine where the PVC was
Tim
Old May 14, 2012 | 10:54 PM
What u do about the baffle box on the under side of it?
Old May 15, 2012 | 02:19 AM
bww3588's Avatar
You can remove it totally and run an inline pcv valve.
Old May 15, 2012 | 02:20 AM
bww3588's Avatar
While your welding the an fitting in, you can fab up some baffles out of aluminum to keep the oil from being sucked thru the pcv.
Old May 15, 2012 | 05:32 AM
I left it in place
Don't have any issues with oil in the catch can
Tim
Old May 15, 2012 | 04:29 PM
alright cool thx for the info!
