ls3 stock injector size???????? ned help!!
Old 08-10-2012, 04:47 PM
backdraft408's Avatar
Default ls3 stock injector size???????? ned help!!
are stock ls3 injectors 42lbs???????
Old 08-10-2012, 05:01 PM
blake b's Avatar
42#@58psi
https://ls1tech.com/forums/fueling-i...flow-rate.html
Old 08-10-2012, 08:08 PM
DietCoke's Avatar
They're 42 lbers @ 58 psi. Same as LS7 injectors.
Old 08-10-2012, 08:55 PM
blake b's Avatar
I saw in the table in the link I posted it shows the LS3 at 41, LS7 at 42 and yet says they are the same injector. I am sure the 41 is a typo as at the end of the same line, it says 42
Old 08-12-2012, 01:32 PM
oakley6575's Avatar
41.7 @ 58psi
Quick Reply: ls3 stock injector size???????? ned help!!
