Solid roller LS2 MS4 cam lash
Old Oct 25, 2012 | 11:21 PM
silverz28camaro's Avatar
Default Solid roller LS2 MS4 cam lash
whats everyone setting the solid roller lash at? I got the intake at .014 and exhaust at .016...so far everything sounds good, just wondering whats the ideal clearance.
Old Oct 26, 2012 | 12:15 PM
Gordon0652's Avatar
Is the core build for a solid set-up?
Old Oct 30, 2012 | 04:03 AM
bww3588's Avatar
That's what I was thinking. If it's not a solid roller grind, I can't see it working well.
Old Oct 30, 2012 | 04:29 AM
LS1MCSS's Avatar
The only specs I found for An MS4 has it listed as hydraulic. If his cam is solid, it must be something other than an MS4.
Old Oct 30, 2012 | 07:22 AM
bww3588's Avatar
Agreed...or something is not adding up
Old Oct 30, 2012 | 07:52 AM
Gordon0652's Avatar
There should be numbers engraved on the Cam on the back side. Find out who is the grinder i.e. CompCams, CAM Motion and call them with the numbers.
Old Oct 30, 2012 | 08:09 AM
bww3588's Avatar
I'm guessing he is trying to run solid rollers with an actual ms4...I'm not 100% how it's going to work out, but there is a reason grinds are different for solid and hydraulic.
