is it possible to delete dbw for cable
Old Nov 5, 2012 | 02:42 PM
Ls_Nova's Avatar
Default is it possible to delete dbw for cable
Just picked up a 2008 6.2 and is going into a foxbody and was wondering if I can ditch the dbw for a cable style throttle body or if its even possible...or what would be the next easiest way to run in a swap....thanks...
Old Nov 5, 2012 | 06:29 PM
socal's Avatar
yes you can. it requires a new TB and tuning
Old Nov 5, 2012 | 06:47 PM
Ls_Nova's Avatar
Was doing research but just couldn't find the answers i needed so i would be able to use the stock harness and computer ???? Just delete out dbw in tune..and run a tb that allows a cable to be ran...
Old Nov 6, 2012 | 05:27 AM
gto_ua's Avatar
ECU wont understand what happened with idle control
+closed to open loop transition will be screwed as it wont see the TPS
+traction control wont work
+ETC rpm limiting wont work
+again, should be open loop SD tune only
but idle - the main question
Old Nov 6, 2012 | 07:00 AM
garys 68's Avatar
Later ecus have no provision for IAC.
You would need an ecu that has IAC capability and runs a 58x crank reluctor. Or get a 24 to 58x converter and use a 24x ecu.
By far the easiest would be get the dbw pedal.
Old Nov 6, 2012 | 12:33 PM
TyCZ28's Avatar
By far the easiest it to get a carb conversion with a square port VicJr intake and the MSD ignition for a 58x wheel...
Old Nov 14, 2012 | 06:12 PM
RWDCelicadude's Avatar
Why not just run the DBW setup? It's really easy to use and if you can do an engine swap I'm sure you can figure out how to mount a pedal. I'm running the stock DBW setup in my RX7 and it works great. Most people don't even realize it's electric after they drive it, at least until they stare under the hood for a minute or so.
