Clean an aluminum engine
Old Jan 22, 2013 | 02:29 PM
ventura2's Avatar
Default Clean an aluminum engine
Any tricks to getting my 6.2 to look like new again?
Old Jan 23, 2013 | 05:47 PM
MIKE93SVT's Avatar
CLR is awesome at taking any type of grime and grit off
Old Jan 23, 2013 | 06:42 PM
RedHotG8's Avatar
I use simple green but don't leave it on the aluminum block or painted surfaces too long.
Old Jan 23, 2013 | 07:22 PM
dhctss's Avatar
I bought a non toxic cirtus cleaner for engines at autozone. I then bought a 4 wire brush kit. My ls1 looks great now and safe on engine
Old Jan 24, 2013 | 06:15 AM
keith102371's Avatar
simple green!
Old Jan 24, 2013 | 06:35 AM
ventura2's Avatar
Excelllent, thanks guys.
Old Jan 25, 2013 | 05:19 PM
nafornow's Avatar
Damn sure dont use purple power. I learned the hard way. Its 11.5-12.5ph corrodes aluminum quickly...and rinsing with water doesnt prevent it.
Simple green I think is a good option (9.5ph), but sure isnt as strong, for cutting gunk/grease. Luckily, when I bought my car, the only gunk was on the steering rack, so it wasnt too bad, getting everything cleaned up under there.
Im not sure, but I think a steam cleaner would by best. Itd be nice if some professional detailers would chime in.
Old Jan 25, 2013 | 05:23 PM
RedHotG8's Avatar
Most of the pro detailers I know use simple green. Steam cleaning works well too but stay away from the electrical connecters.
Old Jan 25, 2013 | 05:31 PM
bryanracing95's Avatar
I used to use the Engine Brite cleaner in the can while at the car wash, used to spray the engine with the hot soapy water then use a can of engine brite, let it sit while you wash the rest of the car and then rinse it off when done. Worked great on my LS2 in my trailblazer ss
Old Jan 25, 2013 | 06:17 PM
LS6427's Avatar
Home Depot
Formula 88 degreaser. Amazing stuff. Mix it 75/25. 75% degreaser.
