Ls7 injectors
Old Feb 17, 2013 | 10:31 AM
hsvgtsr's Avatar
Default Ls7 injectors
Am I right in thinking that ls7 injectors are shorter then ls1 injectors
If they are where can I get ls7 injectors with ls1 connectors
Old Feb 17, 2013 | 10:56 AM
djfury05's Avatar
Yes they are quite a bit shorter.. you have to get EV1 to EV6 connectors I believe. Also you will need LS3/7 specific fuel rails.
Old Feb 17, 2013 | 01:36 PM
hsvgtsr's Avatar
Is there anywhere I can get ls7 injectors with ls1conectors?
Old Feb 17, 2013 | 02:36 PM
djfury05's Avatar
Not that I know of
Old Feb 17, 2013 | 02:49 PM
hsvgtsr's Avatar
I was hopeing that I didn't have to use adapters ow well
Old Feb 17, 2013 | 07:32 PM
ramairws6's Avatar
Yes, and yes. You can get them with the right plug and a shorty style also. Will only have to change out the o-rings. Should be able to find these with quite a few sponsors to the right. Hinson will probably be able to get you hooked up with what you need
Old Feb 18, 2013 | 03:41 PM
hsvgtsr's Avatar
Thanks guys ill check them out
Old Feb 18, 2013 | 04:16 PM
LS1MCSS's Avatar
You don't have to use adapters. Just get the correct connectors and solder them in. You can get any type injector connector you need on ebay.
