HELP! Custom Cam Specs.
Old Mar 24, 2013 | 04:09 PM
2qwik4ya's Avatar
Arrow HELP! Custom Cam Specs.
I have 2002 Trans AM WS6. I will be shipping my stock 241 cast heads off to A.I. for cnc port job. I will be running on the motor so I wanna know what is the BEST CAM. I have read where 228/232 is the best on stock C.I. Any help will be nice.
Old Mar 24, 2013 | 05:12 PM
lil john's Avatar
Talk to Brian Tooley or guy's at Texas Speed that's all you need.
Old Mar 24, 2013 | 05:27 PM
alexus6798's Avatar
Let Phil at A.I. recommend you a cam since your heads will already be there.
Old Mar 25, 2013 | 08:06 AM
Sales@Tick's Avatar
There is so much more to deciding on the right cam specs than just, "I heard 228/232 was the best". How many miles a year you drive the car, idle quality wanted, rpm range you want it to perform best in, what intake manifold is being used, weight of the vehicle, rear gear, stall converter and many many many more things determine cam specs.
I'd be glad to spec a cam and have one ground for you. We have gotten great results with Ai port work and our cams over the years and recently.
Old Mar 25, 2013 | 09:13 AM
2qwik4ya's Avatar
I have a T.C.I 3600 stall i drive anywhere between 80-150 miles a week. I have a LS6 intake, 3.23 gear( maybe switch to a 3.73) The car is stock weight. I want the car to sound aggressive and lopey.
Old Mar 25, 2013 | 05:15 PM
Sales@Tick's Avatar
If you'd like send me a PM and I'll get you a recommendation.
Old Mar 26, 2013 | 01:15 PM
davidws6's Avatar
The 228 / 232 is a proven performer, and with your stall verter, might be fine. Tho, since ur heads are at A I, ask them as they also spec cams.
From this member = Damian's Avatar,, I typically see 415-420rwhp on every 228/232 I install. Been using that cam for years.
Ur ride Auto or Manual ? What rear axle ratio ?
Old Mar 26, 2013 | 08:40 PM
2qwik4ya's Avatar
3.23 stock and auto. I wanna up the gears up to a 3.42 or 3.73
Old Mar 29, 2013 | 08:43 AM
Blackpanther99's Avatar
A 228/232 wont be bad at all for your car. It would be a legit choice! Its a good proven cam, but if you want something custom contact Martin at Tick. He makes amazing cams.
As far as the gears go you should be better off with a 3.73.
