550-600 RWHP Crate Engine
I don't want to build, but exploring "cost effective" crate. Any thoughts on where to go? I looked at MAST, but OMG they are ridiculously expensive.
Livernois, LME, HKE, etc. A solid 427+ engine for that much power would probably be in the $13-15k range.
But an answer to what will make good low end power and keep going 402 with good heads will do the trick and also be alot of fun for the streets
Brian Tooley can sell you a set of TFS heads, port match the intake, and spec you a custom cam.
550rwhp+ is going to need 427ci+ and good heads. Production heads give up low/mid range power over aftermarket castings due to their massive intake ports.
I was recently in the same boat and after calling a few builders, the MAST really isn't a bad deal at all if you want something turn key. I was up around $16k for a turn key 416 ls3 from another builder with ported ls3 heads, not even a good head. I am going to end up going a different direction but can say the MAST becomes pretty tempting as you talk to other builders.
http://paceperformance.com/i-5928405...r-harness.html
