NRE LS3 X-Ram dual plenum intake manifold
#41
UNDER PRESSURE MOD
I'm fighting a belt issue right now where after some hard blasts, the belt is walking off the tensioner pulley, and now it's clearly evident why.
#42
At least they used real street headers, manual water pump and an alternator.
I had an electric pump, and admit no alternator, but did use my old 1 7/8" headers and a steel flywheel. I have 2" now with aluminum.
That thing is making a lot more torque than mine did down low and I thought mine was stout at 561 ft.lbs at 3500 rpm.
#44
I agree, he installed it incorrectly on the driver's side of the crank, but on the other side, the distance between the crank and the tensioner pulley on the passenger side head is correct, and that's what is flopping all around. It would benefit from having another idle there.
#47
No one mentioned how they had to keep bumping the throttle on decel to keep it from stalling.
