Side effects of removing the LS3 intake foam pads?
http://www.lsxtv.com/news/ls3-instan...e-performance/
http://peakspeedshop.com/removal.xhtml
Which said to use 44in/lbs 1st pass 89 in/lbs 2nd pass. I'm not saying they're wrong, but something went wrong. I bought the only in-lb torque wrench I could find locally from Harbor Freight (made by Pittsburgh), set it to 44 in/lbs and it never clicked before I snapped the first bolt. I hand tightened the remainder and used all new gaskets, hope that doesn't cause an issue. Waiting for the RTV to harden around the LS1 MAP sensor before I take it for a spin.
