Can't hook at all
Old Dec 17, 2013 | 10:25 AM
Trannysgonewild12's Avatar
Default Can't hook at all
I have a ls1 with headers and 3600 yank! I have 245x45-16 Hoosier slicks! I do a good burnout and stall up to 2500 and just road the tires! Is there anything I can do to get it to hook?
Old Dec 17, 2013 | 11:03 AM
zzjdzz's Avatar
What air pressure you running? How much rubber on the tires? Are you on your burnout patch when you launch?
Old Dec 17, 2013 | 11:04 AM
I run 15psi and the rubber is still good and yeah I back up right into it
Old Dec 17, 2013 | 01:32 PM
FLVETTE's Avatar
Try holding back WOT for one or two car lengths.
Old Dec 17, 2013 | 01:49 PM
zzjdzz's Avatar
do you flash the converter at launch? 3600 is a little steep, so flash it to 3000 on the hot tires.... does it hook then? (when i say 3600 is a little steep, it's only cause you 245mm slicks)
Old Dec 17, 2013 | 04:21 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
this really should be in the suspension section. Do you have any suspension mods currently? with your performance mods you should be running control arm relocation brackets and tubular lca's to help plant the rear. What gears do you have? Also a 245/45/16 is a pretty short tire, try stepping up to something with a taller sidewall
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Dec 17, 2013 | 09:40 PM
I have no suspension mods and I never tried to flash it at 3k also I'm looking for a 26-10.5-16 slick I think it should work
Old Dec 17, 2013 | 09:52 PM
zzjdzz's Avatar
Let me know! Don't brake the 10 bolt...
Old Dec 17, 2013 | 09:59 PM
I raced a few nights ago on the street and roasted them but somehow still beat the other TA which has alot more bolt-on's than me! But ill deff try it tomorrow
