Prc heads part # location
Hi
I bought used PRC heads and i looking for the part number to get specification and there is no numbers only "PRC" !!
Where can i find PRC heads part # ??
LS1Tech Premium Sponsor
We etch in a part number under the rocker stand. Its a large 5 digit number. If its not there it may be an older set, in which I might be able to help you if you know who bought them from us.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
There is writed only 08/12 and by hand carving "11325" that are what i found , and i dont know how he bought them !!
I looked that number up and those are our PRC 255cc aftermarket LS3 style heads. They came from us with a slight mill of .005 68cc. They have a solid stainless steel intake valve and not the hollow stems. They also came with our PRC .675 dual valve spring kit.
Lonnie
Lonnie
