LQ9 build info help
Old Jan 28, 2014 | 08:27 PM
bsmith78's Avatar
Default LQ9 build info help
Does anyone have a link to an actual build or there own combos that they would like to share. Been looking for threads with not much luck
I am starting with:
Lq9 with low miles from a caddy
Complete LS3 intake except tb
I have a budget but like anyone else I want as much bang for the buck.....It will be going into a 69 Camaro with a full TCI frame with a 6 speed. It will mostly be a street car but would like to get the most out of the engine as possible with out spending all the money on machinists...Any help would be great!!
Old Jan 28, 2014 | 10:17 PM
bsmith78's Avatar
No Help
Old Jan 28, 2014 | 11:00 PM
KCS's Avatar
KCS
Moderator
Gee, a 6.0L build with LS3 intake. No wonder you haven't had much luck finding builds, no one EVER builds something like that...
Old Jan 28, 2014 | 11:04 PM
bsmith78's Avatar
A "search"...tried that not much luck on a proven combo.....not being a smart *** just alittle help.....
Old Jan 28, 2014 | 11:15 PM
KCS's Avatar
KCS
Moderator
Try searching "6.0L LS3". It got me plenty of results...
https://ls1tech.com/forums/dynamomet...-gm-parts.html
https://ls1tech.com/forums/dynamomet...5x3-112-a.html
https://ls1tech.com/forums/dynamomet...p-446rwtq.html
https://ls1tech.com/forums/dynamomet...q4-budget.html
Old Jan 29, 2014 | 09:09 AM
chevymike396's Avatar
the first thing you need is L92 heads before you can run that intake on an LQ9
Old Jan 29, 2014 | 06:36 PM
bsmith78's Avatar
Already planned on the L92s........any good vendor that you would recommend?
Old Jan 30, 2014 | 07:57 AM
KCS's Avatar
KCS
Moderator
GM...
Seriously though, stock heads should suit you just fine. I wouldn't have them ported or anything as they're already too big for a 6.0L in my opinion, but a good conservative cam will band aid a lot. Should be fun with a T56 behind it.
There are LS3/L92 heads in the classifieds sections all the time. I've seen them priced anywhere from $500 to $750 depending on the valves and what else they come with (rockers/springs/etc.).
Old Jan 30, 2014 | 08:26 AM
FastKat's Avatar
BTW, an LS2 is also a 6.0L w/the same bore, stroke, etc. Pretty much any of the info you see on the forums pertaining to the LS2 will also apply to your LQ9 except for some of the wiring. The LS2 has the knock sensors and the cam sensor in a different place.
Old Jan 30, 2014 | 06:35 PM
bsmith78's Avatar
thank you all.......I was trying to looking up LQ9 builds
Old Feb 5, 2014 | 08:46 PM
bsmith78's Avatar
do I have to move the knock sensors if I run the ls3 heads and intake? any mods to the block?
Old Feb 6, 2014 | 05:14 PM
george g's Avatar
Nothing special to put ls3 heads on a 6.0, just the heads and intake.Everything stays the same knock sensor and such.Make sure you get a cam designed for ls3 heads and check ptv clearance.I would mill the heads to get some compression bump.LS1GTO.com has a nice write up.
Old Feb 18, 2014 | 06:01 PM
bsmith78's Avatar
Alright I have decided to go with the stock ls3 heads with upgraded patriot valves...what lifters would be the best also roller rockers what ratio......I read the Pat G build that someone posted above...I like that combo how do I get ahold of him to spec a cam?
Old Feb 18, 2014 | 07:15 PM
ez2cdave's Avatar
Here you go . . .
http://tinyurl.com/lz8btsp
Old Feb 18, 2014 | 09:21 PM
bsmith78's Avatar
I seen calling local dealership to see if they can meet the same price
Old Feb 20, 2014 | 04:07 AM
mcdonald77's Avatar
Here is my build thread, its long but has lots of pictures.
I started with a 200,000 mile 04 LQ9. For the mileage it still had cross hatches on the cylinder walls. I had it bored to 4.030, used speed pro pistons. It made 374/370 with an ls6 cam. I am pretty sure 400 was possible if I tuned the spark table. That cam is gone and I am currently trying to decide what cam route to go. I used stock L92 heads. Those heads are getting BTR springs, valve job and a light decking if needed.
http://www.s10forum.com/forum/f213/l...-jimmy-464706/
Old Feb 24, 2014 | 09:39 PM
bsmith78's Avatar
LS3 with 660 springsHeads are on there way from SDPC what cam and lifters would you guys run...is a custom cam worth it?
