Just grabbed an LY6
Old Feb 7, 2014 | 12:56 PM
kainedogg's Avatar
Default Just grabbed an LY6
I already have an aftermarket cam (from an LQ4) for it but that would mean tossing the vvt out in the cold? Anyone care to share their combos with and without boost? It is going in a Chevelle with a 3k stall with a 4l80e behind it. S480 turbo down the line somewhere.
Should I keep it? Is it worth the hassle? Will I have problems down the line with boost.
Old Feb 7, 2014 | 05:17 PM
tiresmokinV8's Avatar
I have an 08 ly6 with a TSP vvt-2 cam. and 80e. Makes great power and I plan on running a turbonetics 7875 in the future.
Old Feb 7, 2014 | 05:41 PM
kainedogg's Avatar
How much was the cam. Did you have it dynoed before and after installation? What springs does it take? I assume these motors only have vvt right not the dod crap?
Old Feb 7, 2014 | 06:13 PM
Cam kit with pushrods and springs and phaser limiter came out to around 800ish. Did the whole engine build up before I swapped it into the truck so no before and after times or dynos. And yes these engines only have vvt no dod!
Old Feb 7, 2014 | 08:55 PM
kainedogg's Avatar
Sweet swap friend. Thanks
Old Feb 10, 2014 | 05:25 PM
DWS's Avatar
DWS
I have an LY6 and 4L80e going into my 81 Firebird to get rid of the old 4.4l that's in it now. I'm keeping the vvt and will probably go with a Mast cam and spring kit, plus a 3000-ish stall. I have an LS3 intake as well to keep it tucked under the hood. Other than that, I plan on keeping it stock.
It will be a sweet swap like kainedogg said.
Old Feb 10, 2014 | 05:53 PM
kainedogg's Avatar
Are you going to do a build thread DWS?
Old Feb 11, 2014 | 10:12 AM
DWS's Avatar
DWS
Yeah, planning on it when I get time.
Right now I have the engine on a stand in the garage mocking me... Going to drop the 4l80e off at a trans shop to do a once through to check it out in the spring. Got to replace the output shaft and they said they'd do it for me as part of the check. no charge for the part - they take my 4x4 shaft and give me a 2wd shaft. nice.
The Firebird is my daily driver right now. I am planning to pick up a new vehicle for the wife in July so I can take it over the old one and pull the Firebird off the road and not be super rushed on the swap.
What are you planning for headers? I am thinking of mid length as my chevelle bottomed out the long tubes on speed bumps all the time....
Cheers,
Ds
Old Feb 13, 2014 | 09:26 AM
kainedogg's Avatar
F-body bbk shorty headers for now bro.
