Will this manifold and ignition work?
Old Feb 17, 2014 | 09:00 PM
Powe's Avatar
Default Will this manifold and ignition work?
I'm wanting a street 425rwhp street car out of my lq4. I plan to get it from the top end and cam. I have a stock lq4 (complete with all accessories) and need basically everything including ignition, fuel pump, after market injectors, drive bay cable tb, cam heads, headers CAI etc. Basically my question is how do I get there? I can grab some stock ls3 heads on the cheap then this https://sdparts.com/details/edelbrock/e35393 next get a custom cam... All this in a gen two camaro with T56.
Old Feb 24, 2014 | 07:04 PM
LS1MCSS's Avatar
The setup in the link won't help you. Did you read the description? Get a junk yard rebuilder motor and get the complete intake and heads off of it. Below is the description of the parts in your link.
(They come complete with everything required to install them on a small block Chevy with conventional or Vortec-style cylinder heads.)
Old Feb 27, 2014 | 09:55 PM
LLLosingit's Avatar
Maybe I missed something but where did you read that? The system in the link he posted is for the "LS series"
Old Feb 27, 2014 | 10:05 PM
LLLosingit's Avatar
If you're not set on EFI I would go with CNC LS3 Heads with Edelbrock Carb Victor Jr Intake and MSD controller. Then look at better springs/cam and headers. 425rwhp should be attainable.
Old Feb 28, 2014 | 04:57 PM
LS1MCSS's Avatar
That part of the description that says "SBC with conventional or vortec style heads" should be removed if it's for an LS engine.
