85mm maf on 98 LS1 Fbody
Old May 5, 2014 | 07:26 PM
Mr. Trick's Avatar
Default 85mm maf on 98 LS1 Fbody
Can I use the standard 5-3 wire adapter, and also I wont need the IAT in the lid anymore correct? I wasnt sure if thats all I needed since it seems 98s are different for everything.
Old May 22, 2014 | 04:08 PM
mjcotroneo's Avatar
there are two different harness' to look for make sure you get the right one. people sometimes buy off of ebay and the pins are wrong. if you do get the correct one what i did was throw my sensor away and i sanded, filled in the hole on the lid with abs plastic, and painted it. i decided to have mine tuned to make sure the tables are correct.
