lq4 with ls3 top end questions
http://www.tickperformance.com/tick-performance-sns-torquemax-stage-2-camshaft-for-ls1-ls6-engines/
This cam will make some strong power, but will need good rear gears, a high stall converter(3000+) or a manual trans. You also need to get good valve springs. Tick will make sure you get the correct springs. If you want a milder cam, just contact Martin at Tick or Brian at Brian Tooley Racing and tell them your combo.
http://www.tickperformance.com/tick-...1-ls6-engines/
