Overheating problems and I cant figure the problem out
Old Sep 15, 2014 | 03:56 PM
dash94vert's Avatar
Question Overheating problems and I cant figure the problem out
I have a turbo car thats hot already but the damn things keeps over heating after about an hours woth of drive time! I have a ron davis radiator for my gto i changed the cap thinkiNG THAT MAY HAVE BEEN THE PROBLEM BECAUSE THE LAST ONE WAS A BIT WORN BUT THAT DIDNT WORK, then I changed my thermostat to a 160 degree and that didnt work either! the water pump is working properly as well so what else is there to do??? I'm stumped here PLEASE PROVIDE HELP!
And if this was vague i'll provide any other info on the car!
Old Sep 15, 2014 | 04:36 PM
RedEvilz28's Avatar
it could be air bubbles in the coolant system take the radiator cap off start the car let it get hot and at the same time squeeze the upper and lower hoses u should see air bubbles an top the coolant off as it gets low also
Old Sep 15, 2014 | 05:06 PM
LS6427's Avatar
If you no longer have the factory plastic fan shroud assembly.....you are fighting an uphill battle. A lot of people who use aftermarket radiators cannot or don't use the factory shroud.......The factory shroud is the most important single part of the cooling system.
Also....go to a 180* tstat.....160* tstats don't close after awhile and then you have one big hot water heater just continuously moving hot water through and it never stops flowing and the coolant never gets any SIT time to cool off in the radiator.......the coolant MUST be able to stop flowing completely (tstat closes) and cool off before it returns to the heads/block.....
Once your tstat does not close......youre doomed and you will soon overheat. At least during city or stop and go driving. Cruising on the highway would cool it down enough to close it.
BUT.....you have to get a shroud on it....or fab one up that is sealed all the way around the edge of the back of the radiator so 100% of the air hitting the front of the radiator gets pulled through it. Fans just mounted to the back of a radiator is terribly inefficient as far as air flow cooling because the only part of the radiator surface that's actually cooling any air is the area under the fan blades......
Old Sep 15, 2014 | 06:51 PM
ddnspider's Avatar
Actually you don't need the stock shroud. I've done 2 turbo cars now, one with a 180 stat and one with a 160, both had cut stock fan shrouds and neither overheated. However, it IS important to use puller fans not pushers. To the OP, have you done anything to open up the grill or front bumper to get more air to the radiator? Did you jack up the front end and ensure there is no air in the system? Have you tried running straight water with water wetter?
Old Sep 20, 2014 | 11:30 PM
LLLosingit's Avatar
Not how it works exactly, The thermostat is before the radiator so engine temperature controls whether or not the thermostat opens or closes not coolant temperature in the radiator. The thermostat is there to maintain minimum temperature not maximum temperature so a thermostat stuck open will not cause an overheat issue but the opposite the engine could run to cool. A thermostat stuck closed on the other hand will overheat.
Old Sep 20, 2014 | 11:41 PM
LLLosingit's Avatar
Do you have the hoses running to the heater core hooked up? I only ask because other people have plugged them off and had overheating issues until they hooked them back up or ran a bypass setup (loop).
Old Sep 24, 2014 | 02:23 PM
dash94vert's Avatar
All i usually run is distilled water and water wetter. I opened up the grill when we took the front bumper off to get the intercooler in there BUT i cannot say if the fans are pushers or pullers but im definitely going to check on that when i get back home!
I jacked up the rear end and let the car idle about 5 times already and it lightly bubbles but the problem still persist. The weird thing is that Ive tried everything and it still runs hot randomly. I havent tried the factory shroud so ill try that as well. i get so damn mad at it i contemplate driving around with the hood off lol
Old Oct 8, 2014 | 01:54 PM
saccitycorvette's Avatar
LS1Tech Sponsor
Hi,
Is it getting hot while cruising down the road or in traffic?
__________________
Don't forget to check out our products at www.saccitycorvette.com
https://www.corvetteforum.com/forums...c361808_12.gif
If you like our products, tell others! If not, tell us! https://www.corvetteforum.com/forums...s/thumbsup.gif
Old Oct 16, 2014 | 09:12 AM
lsexpress's Avatar
are you sure there no air in the system
Old Oct 19, 2014 | 08:02 PM
InsaneDomestics's Avatar
Could be something as simple as changing the radiator cap, AGAIN.
When under pressure, water and engine coolant boil at a higher temperature. As your coolant and water increase in temperature and approach the boiling point, the state of the liquid begins to change to a gas, seen as steam. A gas is much less efficient in cooling your engine than a liquid. So INCREASING THE PRESSURE INCREASES THE BOILING POINT, allowing the coolant and water to do a much better job at removing heat. Keep in mind that internally coolant running through the channels within the engine will come on contact with metal that is well above 210° F so preventing the coolant from boiling is essential. By INCREASING THE PRESSURE, YOU ARE INCREASING THE BOILING POINT and the coolant remains in a state of liquid rather than converting to a gas. Heated coolant also expands so a closed loop system will require coolant to be held in rather than boiled out. A closed loop system will also need an overflow tank which is reclaimed upon cooling of the system.
