LQ408 injector questions
Old Oct 6, 2014 | 12:00 PM
KyleLanter's Avatar
Default LQ408 injector questions
What is a good injector to run on a 408 stroker? Basic 408 sporting ls3 heads and a fast 102 and TB looking to make around 550hp. I am just looking for suggestions from others with more experience.
Thanks guys.
Old Oct 7, 2014 | 02:41 AM
Werewolf SS's Avatar
Well I'm running a 408 stroker, Ls3 heads, ls3 intake, 102mm tb and turning up to 7k rpm. I'm running 42lb GTP Injectors. Still working on the tune and dialing things in but it appears with my cam and spinning at 7k I'm close to 90% IDC with it being on the rich side. Once I lean the AFR to a normal range I expect my IDC to be about 80 to 85%.
Fueling requirements depend on several factors. How high an rpm your going to spin the motor. What the motors Volumetric efficiency is. Any power adders (boost or nitrous if dry shot). There are formula's you can use to deduce fueling needs based on estimated horsepower. In fact here's a link to one http://www.promracing.com/injector.php this is assuming flywheel horsepower which I'm guessing is what you mean by 550hp. If your referring to rear wheel horsepower then you have to understand flywheel is going to be a higher number depending on drive train. Typically 15% for manual, and 20% for automatic is the typical estimates.
Best of luck.
Old Oct 7, 2014 | 09:11 AM
KyleLanter's Avatar
Thanks Werewolf for all the input I will continue my research but you have been a lot of help.
Old Oct 13, 2014 | 11:38 PM
Last C5's Avatar
My 408 is turning 520 rwhp and I'm also using 42lb flow matched injectors.
7K is also my redline as this motor is in my track car.
Old Oct 14, 2014 | 11:43 AM
KyleLanter's Avatar
Those are great numbers and what I am looking to do. Thanks for the advice.
Old Dec 21, 2014 | 04:19 PM
need4speed069's Avatar
check this out
http://www.gtsparkplugs.com/InjectorSizeCalc.html
