Electrical questions for a 408 build
Any help/ suggestions would be appreciated.
Thanks all.
Are your knock sensors still in the valley cover on the 408? Cam sensor in back or front of motor?
As far as the knock sensors I do not have any as I broke them when tearing down the lq4 so they will be replaced and us the ones that are in the valley cover. Also my understanding of LQ's are that the cam sensor is located under the valley cover and the hole will need plugged if I move it to behind the timing chain cover? I do not have an exact answer on that though as I have not got to that point on the build yet.
Unless you want easier access to it from the front, it seems like leaving the cam sensor in the LS1-style location will save you from buying the extension harness to get the front LS2+ front sensor location connected. Only about $30 though
Thanks for the advice on the replacement knock sensor harness seems like a good deal for only 30 bucks.
