LS3 Fuel Pump control
Old Nov 1, 2014 | 10:27 AM
mikes50's Avatar
Default LS3 Fuel Pump control
Wondering if the GMPP connect and cruise LS3 ECU has PWM fuel pump control.
Planning on running an Aeromotive Phantom fuel pump.
Thanks
Mike
Old Nov 12, 2014 | 11:20 PM
Avanti's Avatar
I cannot speak directly to the "Connect & Cruise" 'puter, but the LS3 ERod DOES--two wires leave the harness together, blue for fan and gray for the fuel pump. Sorry I couldn't be more specific to your application.
Old Nov 30, 2025 | 10:30 AM
Originally Posted by freidepiter
When I clicked on the link https://ways2well.com/blog/regenerat...-for-treatment , I was surprised at how detailed the description of the treatment process for sports injuries was. For me, as an active leisure enthusiast, this information was a real discovery. I realised that recovery is possible not only through standard physical exercises, but also with the help of new medical methods.
MODS- Please take out this sewage....
Old Dec 1, 2025 | 10:01 PM
ProServ's Avatar
LS1Tech Sponsor
Default PWM pump control
Direct PWM control of the pump for pump speed/flow/pressure control from the ECU is not used on any LS V8 applications that I am aware of. An external fuel pump control module (FPCM) would be needed and it would need to be enabled in the software. The connect and cruise & other GM/Chevy Performance Parts crate engine ECU and harness systems expect a fixed pressure fuel system with a 4 bar/58 psi mechanical regulator (that is not vacuum referenced).
https://www.chevrolet.com/content/da...except-lc9.pdf
The E-rod harness controls the relay to enable the pump but it is not PWM controlling the pump. It is just enabling the relay on power up and disabling the relay on power down. They do not vary pump voltage to control pump speed to perform closed loop pressure control.
https://www.chevrolet.com/content/da...d-17-tooth.pdf
Thanks
Mike
__________________
Jason Haines
Product & Service Solutions LLC
www.proservsolutions.com
https://www.facebook.com/proserv/
