Ls2 cam
Old Nov 28, 2014 | 02:39 PM
JacobC's Avatar
Default Ls2 cam
I am swapping my ta with an ls2 and I'm going to go with an after market cam... I was wondering what is the biggest cam I can put in there with max amount of power without fly cutting the pistons, and I do know new valve springs will be a must..
Old Nov 28, 2014 | 08:38 PM
nexvctm2001ss's Avatar
Google is your friend....any mods?...and why the largest?
Old Nov 29, 2014 | 03:53 AM
Dyno Junkie's Avatar
I fitted a CompCam 235 243 .621" .624" 113 to friends manual HSV GTO.
Has a nice idle and revs clean to 7,200rpm.
Old Nov 29, 2014 | 10:46 AM
JacobC's Avatar
No mods, I'm just putting in a stock ls2 but wanted to put a bigger cam in it. I want the largest because I want the most amount of power..
Old Nov 29, 2014 | 10:48 AM
JacobC's Avatar
Do you know what the numbers were on the dyno?
Old Nov 29, 2014 | 04:02 PM
Yes I do, however there is not much point posting them as Australian dynos appear to have a different calibration to USA dynos.
Old Nov 29, 2014 | 06:22 PM
No mods and you want the largest camshaft for a ls2? .....you definitely need to rethink things or you'll end up with a turd on the street
Old Nov 30, 2014 | 08:46 AM
JacobC's Avatar
You can just post them any way so I kinda of have an idea
Old Nov 30, 2014 | 08:47 AM
JacobC's Avatar
That is correct, but I did say the largest camshaft for a stock ls2 without having to flycut or get new heads...
Old Nov 30, 2014 | 03:13 PM
Manual HSV GTO LS2 made 416rwhp.
On the same dyno our auto Monaro LS3 makes 415 with converter unlocked.
Old Dec 1, 2014 | 06:15 AM
JacobC's Avatar
Nice... Is that with stock heads?
Old Dec 1, 2014 | 06:31 PM
Pseudonym's Avatar
GET A CUSTOM GRIND! I recommend Vengeance Racing or Tick Performance. They can spec it and have it ground for you.
Old Dec 3, 2014 | 07:06 AM
Stock LS2 with:
Pushrods
BTR springs
Double row chain
RamJet OTRCAI
1 7/8 4>1 extractors
3" cats
3" into 2 1/2" twin system
Has so far run 12.20 and 115.8 mph crossing the line in third gear.
