ls6 intake on a ls2?
Old Nov 30, 2014 | 11:44 AM
showdog75's Avatar
Default ls6 intake on a ls2?
What makes the ls6 intake so desirable? Is it better than the stock ls2 intake? If so in hp how much better? Just trying to learn more about these awesome engines. Thanks
Old Dec 1, 2014 | 04:35 AM
showdog75's Avatar
Anyone?
Old Dec 3, 2014 | 12:05 PM
Skidog5150's Avatar
I may be wrong, but it's my understanding that they're about the same in performance except that the LS6 uses the cable driven throttle body and the LS2 doesn't which creates an install problem in the 4th Gen Fbodies.
People with more Tech experience please chime in.
Old Dec 3, 2014 | 12:23 PM
HCI2000SS's Avatar
It's simply a better design, and might give you another 10 hp or so
Old Dec 3, 2014 | 02:10 PM
redtan's Avatar
The intake manifold itself does not care one bit what type of throttle body is used at the end of it. Both can be setup with either throttle choice.
Old Dec 3, 2014 | 02:20 PM
Skidog5150's Avatar
Got it.. both are different sizes so some mods would be required.
Old Dec 3, 2014 | 03:50 PM
98RedZone's Avatar
The LS2 TB is 90mm and a different bolt pattern than the LS6 (78mm?). There are adapters made to bolt them together.
http://www.ebay.com/itm/LS1-LS6-90mm...-/131300255748
Old Dec 3, 2014 | 04:44 PM
redtan's Avatar
I do believe they make cable of dbw units in both sizes. I know of people with 4 bolt cable driven TBs on FAST 102 intakes and others with 3 bolt dbw TBs on stock LS6 intakes.
Look at the V1 CTS-Vs, they have the LS6 intake but a dbw throttle.
Old Dec 21, 2014 | 04:14 PM
need4speed069's Avatar
check this out
http://completestreetperformance.com...products_id=31
