Cam Position Sensor (GEN III TO GEN IV)
Old Jan 4, 2015 | 09:31 PM
2002xREDxZ28's Avatar
Question Cam Position Sensor (GEN III TO GEN IV)
I have a 02 LS1 car and am building (my first build) a 403 based LS2. I have the block with the Gen IV front cover with the CPS. I know I will need a Gen IV cam sprocket, but with the proper cam sprocket will my computer read the Gen IV cam sprocket? Or is there something else that needs to be done to make this work?
Thanks In Advance
Old Jan 5, 2015 | 12:30 PM
maroonls1z's Avatar
58x or 24x crank?
Old Jan 5, 2015 | 06:41 PM
24x reluctor. Gave LPE a call today and their tech support said I'd need the 1x 3 bolt sprocket. Does that sound right?
Old Jan 6, 2015 | 01:34 AM
Jontall's Avatar
That's right.
Old Jan 6, 2015 | 05:00 AM
maroonls1z's Avatar
If you have a 24x ls2, use the 1x cam sprocket and call it good http://juicedmotorsports.com/techinfo_lsx_camgears.html
Old Jan 10, 2015 | 12:33 AM
01WS6/tamu's Avatar
And cam sensor extension harness and will need to drill the block for LS1 knock sensors.
Old Nov 11, 2015 | 08:43 AM
JeepMafiaLS1's Avatar
Default Gen IV cam in Gen III block
Hey guys, i got a LM7 i plan on boosting. I want to get the ls9 cam since it is cheap, other then buying the ls2 front cover, cam sensor, 1x cam sprocket and extension harness, how or will my computer that came with my Gen III 5.3, read the 1x cam sprocket. If anyone that has done this before, give me some info please.
Old Nov 14, 2015 | 08:26 AM
stevieturbo's Avatar
You can buy kits of the front cover/sensor/gasket etc dirt cheap from Summit and LPE etc
eg
http://www.summitracing.com/int/part...3906/overview/
then just add a 1x camwheel for your chosen cam/gear, and wiring changes of course.
Old Dec 17, 2015 | 10:00 AM
S10xGN's Avatar
Has anyone extended the wiring using plain wires instead of shielded cable? I have an older Holley LS1 harness that I'm converting over to use with 58x sensors and am unsure if there'll be interference with plain wires. I have no access to the shielded wiring and this runs pretty close to my alternator...
Old Dec 17, 2015 | 01:09 PM
There is no requirement for shielding on hall effect signal wires. Plain cable will be just fine.
It will do no harm to shield them correctly, but it is not needed.
Old Dec 17, 2015 | 09:23 PM
S10xGN's Avatar
Thanks, Stevie. I was concerned because the Holley HP harness has shielded wires for both CAM & CKP. I've got a tech e-mail in to Holley just to see what they say, but most of the CAM extension harnesses I see are all plain wire...
