MSD Atomic AirForce LS7 Intakes Now Available!
I'm proud to announce the first batch of Atomic LS7 intake manifolds are shipping to vendors! We have 14 still available that will arrive next week! If you want your name on one give us a call or order online! Then following week another 25 will be available!!
From MSD:
When you’re serious about power for your LS7 engine, call in the AirForce! The all-new MSD Atomic AirForce intake manifold delivers improved airflow and distribution to improve the performance of stock and modified engines.
The unique bell-mouthed runner entrances maximize airflow and minimize shrouding - all while optimizing the available plenum volume for an unobstructed flow path over opposing runners. The polymer molded 2-piece design allows for easy access to the runners for porting.
Atomic AirForce accepts an OEM or 103mm throttle body as well as stock or aftermarket fuel rails including MSD’s Atomic LS EFI system. The intake bolts on and is supplied with new gaskets and hardware for a direct bolt-on package.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Don't forget to check out our products at www.saccitycorvette.com
https://www.corvetteforum.com/forums...c361808_12.gif
If you like our products, tell others! If not, tell us! https://www.corvetteforum.com/forums...s/thumbsup.gif
It's touching the inner hood skin. Not willing to put a cowl on it. I wonder if the FAST LSXR (LS7) would have any better clearance?
Ryan
Not complaining, just curious. It still saves $200 over the FAST because you can use the OEM fuel rails.
. If erryone sent me a $100 i will buy a msd and dyno test it
. I just need more people than Doug does lol
