Replacing Rear Main Cover Question
Once the engine is off the stand and propped up on blocks, can I simply remove the cover bolts and the two oil pan bolts that thread into the cover and remove/replace the cover/seal without dropping the oil pan away from the block?
In other words, will I be alright simply removing two oil pan bolts? Or do I need to loosen more of the oil pan perimeter bolts to drop the pan from the block a bit? I'd rather not mess with the oil pan seal any more than necessary. Especially since the pan will be supporting the engine while it's off the stand.
Thanks.
Tipsy
As it is, I'm simply replacing the seal as preventive maintenance. It's got about 71K miles on it. I don't want to create a problem where one does not exist.
Tipsy
Tipsy
If you torque the cover down without the pan on, it can be tilted slightly to one side or the other, and if you leave the pan loose and torque it down using the bottom pan bolts, you will pull the cover down slightly and the seal will be a little tighter on the top side. You want to make sure you torque it down where its straight, but not pulling in anyone direction. An alignit tool makes quick work out of this but its not that difficult as long as you dont have it misaligned when you torque the bolts back down.
Tipsy
Regardless, I removed the old cover and installed the new cover and seal with the pan in place. And your point about the cover being pulled down to the pan is taken. That was a concern I had yesterday while doing this. But with the seal already in the cover, I didn't really see what else I could do. The Align-it tool would simply sit flush against the already installed seal doing nothing to prevent, as you say, the seal from being tighter on the top side (or potentially, the bottom side).
Tipsy
I should have waited and got the tool in the first place.
Tipsy
Tipsy
I know there have been a lot of people who successfully replaced the rear cover without the tool. I thought that I would be able too but found out otherwise.
Tipsy
