Engine and tranny install from top
Old Jun 9, 2015 | 06:08 PM
Thornton98's Avatar
Default Engine and tranny install from top
I recently had to rebuild my engine which I had took out from the top. Is it possible to go ahead and bolt the transmission to the engine and install both through the top so I don't have to wrestle with the transmission under the car on shaky jack stands?
Old Jun 10, 2015 | 07:51 AM
wes1980's Avatar
You can install this way on most vehicles. I've done it to many
Old Jun 10, 2015 | 08:27 AM
blackbyrd's Avatar
it can be done, ive seen someone pull the engine and tranny out together on here I think.
something to consider though, you may need to get the car on jack stands, that way you have enough depth to drop the E&T in a bit more before you have to start tilting the tranny back under the car into position. Hope that makes sense
Old Jun 14, 2015 | 12:19 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
you can do it, but u would leave the heads, intake and front accessories off to have more room.
Old Jun 15, 2015 | 12:39 PM
Thornton98's Avatar
Thanks guys. I had went ahead and did the motor and tranny seperate. But curse those solid motor mounts. 👿
