LS Steam Vent Lines
Old Aug 10, 2015 | 07:54 PM
tadams72's Avatar
Default LS Steam Vent Lines
Trying to decide if I should cap the tears and just run the front or move to a four corner system. Not going to pay Kurt Urban prices in this but also not seeing a lot of options for setups that work around a FAST LSXr manifold. Any suggestions?
Also, in the event I reuse the stock LS3 front line, where to I get the o-rings? Seems I lost one in the tear down last year. Thanks.
Old Aug 11, 2015 | 03:29 AM
SHovV's Avatar
I'll be drilling and tapping my LS7 heads and making my own lines. I'm also using a FAST 102 intake. The -4 AN fittings that go into the back port locations were 15$ from Pep Boys. Just need to buy some -4 line and some more fittings. I can't see having much money at all tied up in it, and if you wanted to get real cheap, get some brass NPT fittings, barb fittings and rubber hose.
For the front o ring fittings, I would imagine you could get them from any auto parts store
Old Aug 11, 2015 | 07:24 AM
drew408's Avatar
They sell the fittings on eBay for like $5 each shipped...
Old Aug 11, 2015 | 10:37 AM
KiwiKid's Avatar
Hi SH,
Yes thats exactly what we do.
Cheers,
Mark
Old Aug 11, 2015 | 01:18 PM
tadams72's Avatar
Makes sense. Wish I would have thought about that earlier. As it stands, too far along in assembly to go back so going to have to look at other solutions for now.
If anyone has some photos of their setup with a FAST/factory style manifold I'd be interested ins seeing them. Thanks.
Old Aug 12, 2015 | 07:07 AM
conan's Avatar
There are a few different setups in this thread...
https://ls1tech.com/forums/generatio...ant-tubes.html
Old Aug 12, 2015 | 12:16 PM
tadams72's Avatar
Some more ideas. Going through it now. Thanks.
Old Aug 14, 2015 | 11:24 PM
BOLO's Avatar
I believe TFS makes a braided stainless steel vent kit with AN fittings available through Summit Racing.
Old Aug 15, 2015 | 02:06 PM
tadams72's Avatar
Yeah seems to be some issues with fitment issues with the FAST manifold and it was back ordered last I checked.
Thinking of going stock on the front and LQ4 line on the back and tying them together. Other thing I am thinking about is just bending my own hard lines. Comparing cost for the fittings to see how much that would be.
Old Aug 20, 2015 | 08:18 PM
87dimeblazer's Avatar
I ran the factory coolant lines under the Fast 102. It took about 4 hours, but I was able to slowly tap the lines to more of an oval and got them laying flat against the valley cover. Then shaved a very small amount of material off the bottom of the intake. I pressure checked the lines before the final install and all lines ran water without leaks and everything fit like a charm.
Old Aug 30, 2015 | 12:45 PM
slogo's Avatar
This is not my thread but I saved it, thinking I might try it, its about 6 or 7 post down
Old Aug 30, 2015 | 12:47 PM
slogo's Avatar
Ooops, sorry didn't click on what Conan had.
Old Aug 30, 2015 | 07:50 PM
tadams72's Avatar
That's basically what I decided. Rear is off an escalade and front is stock LS3.
Old Sep 17, 2015 | 08:53 PM
tadams72's Avatar
So here's the solution. Front steam vent lines from an Escalade, some stainless tubing and Swagelok brass fittings. Total cost about $35 for the Escalade piece and a hookup from a buddy on the rest. Turned out really good.
Attached Thumbnails LS Steam Vent Lines-photo532.jpg   LS Steam Vent Lines-photo56.jpg   LS Steam Vent Lines-photo391.jpg
Old Sep 18, 2015 | 07:37 AM
conan's Avatar
Looks good man, clean and simple.
Old Sep 18, 2015 | 08:30 PM
S10xGN's Avatar
I haven't run lines yet, but I took four block-offs and drilled/tapped them for 1/8" NPT. Will use either 3/16" SS brake line and compression fittings or push-loc stuff...
Old Sep 18, 2015 | 11:25 PM
slocaddy's Avatar
I just put a front set on the back.......not as pretty as yours......
I'll just connect with rubber hose. Not pretty , but cleared everthing just fine[/I]
Old Sep 19, 2015 | 11:24 AM
tadams72's Avatar
I think there are some pretty nice setups out there but I am a function over form guy first. If I can have both that's great too. One thing I like about this particular mid is the simplicity. Looking good for many of us so far.
