L83 air pump, ac compressor
I have 2014 l83. There is a vacuum pump on the drivers side where I need to mount a power steering pump. Does the engine really need this? Also can I use the ac compressor? I have been told it is variable capacity and will not work. Is there some way to make it run off of 12 volts at 100%?
I have done LS2,LS1,LM7,and the New Coyote 5.0 swaps, this can't be any more difficult. Good luck.
Lonnie
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
