Coil harnesses
Old Feb 6, 2016 | 08:31 PM
showdog75's Avatar
Default Coil harnesses
Not sure if this is the best place for this but I'll give it a go. So I've got a e40 ls2 and I've bought a set of the Holley valve covers that the coils mount directly on. My issue is the coils on my engine(12558948) the plug goes in from the bottom. It wouldn't look right with the harness hooked up like that. With that said I bought a set of ls7 coils(12573190) that the plug is on the top but after getting them I realized the harness plug is different. Does anyone know of a harness that'll hook up to my engine harness and these ls7 coils? Thanks
Old Feb 8, 2016 | 03:36 PM
Project GatTagO's Avatar
http://www.rockauto.com/en/moreinfo....442777&jsn=595
Andrew
Old Feb 8, 2016 | 05:48 PM
showdog75's Avatar
Thank you Andrew. That looks like exactly what I need.
Old Feb 8, 2016 | 05:51 PM
Sure thing...I actually made my own harness because I am using the Holley Dominator with a Holley HiRam intake. I wanted the coil wires hidden and to run them under the intake.
Andrew
Old Feb 8, 2016 | 06:01 PM
showdog75's Avatar
Slick setup. I wanted to check out the Cougar at the ls fest but you were always on the go. Maybe this year.
Old Feb 13, 2016 | 07:28 AM
showdog75's Avatar
Thanks again Andrew I got my harnesses yesterday from Rockauto. Exactly what I was looking for.
Old Feb 13, 2016 | 11:03 AM
Glad to help!
Andrew
