cut to fit plug wires
Old Feb 13, 2016 | 07:35 PM
Seeker1056's Avatar
Default cut to fit plug wires
anyone out there with a supplier or part number for a reasonably priced set of cut to fit spark plug wires?
I am moving my coils down between my frame and the motor for my twin turbo setup and need much longer plug wires with 90 degree boots
thanks
Old Feb 15, 2016 | 04:58 PM
JustAFooL's Avatar
thanks
I looked for a week or so and couldn't find any thing different so I broke down and ordered the msd Kit. They come with 45* boots and the wires are very long. Took me about 15 minutes to mark/cut the wires to length and I've spent the last 2 hours putting the boot on ONE wire. Literally been the biggest pain in the *** on the entire build.
Old Feb 17, 2016 | 07:30 AM
Seeker1056's Avatar
found the cheap solution
buy any cheap cut to fit wires and use these terminal ends to make your relocation plug wires
http://www.summitracing.com/int/parts/tay-46069
I figure you could be all in and done for under $70 for a custom set of wires
Old Feb 22, 2016 | 09:14 AM
BOLO's Avatar
MSD #32079 Universal LSX custom cut to required length wires. You can get them at Jegs or Summit.
