LS7 complete engine and trans $2500?
Old Feb 29, 2016 | 04:41 AM
BlackedOut LS1's Avatar
Default LS7 complete engine and trans $2500?
So a friend of my neighbor says his that friend has a LS7 motor and Trans from his wrecked Vette for $2500. I'm just looking for a little guidance if this is valid and the motor is in good shape. I just rebuilt my LS1 and now I have the fever!
Old Feb 29, 2016 | 06:56 AM
cali_bear2003's Avatar
The first questions to ask, what year is the Corvette? That price would be more in line with an LS1 combo. Also, is the trans an auto or manual? Many who are not LS Tech people are easily confused by all the numbers.
Old Feb 29, 2016 | 09:07 AM
Yeah you're right, he said it was an LS7 , but maybe it's a LS6. But if he really has the correct engine for that price I don't think I can turn that down.
Old Feb 29, 2016 | 09:54 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I'd act oblivious and STILL try get it for 2k, lol. OP, if that's a true LS7, you've found the deal of ALL deals, my friend.
Old Feb 29, 2016 | 07:40 PM
S10xGN's Avatar
Depends on the degree of "wreckage" whether or not the block is ruined...
Old Mar 1, 2016 | 03:22 AM
HotRodLS1's Avatar
It's very cheap for a functioning LS7.
Look at the RPO numbers of the heads, block, intake and so on.
Also check if the block is intact.
Old Mar 2, 2016 | 01:40 PM
Rudy72's Avatar
The LS7 never came with an auto until now, C7 and if its complete and turns over, has compression in all cylinders and isn't way over in miles it would be a good deal, if you have to rebuild it to get it working, maybe not so much... you call the block alone if good has a great foundation for a build, longer skirts for stroker build and you have a good crank and block to begin a rebuild with at the very least... always follow what your gut tells you and have fun!
Old Mar 3, 2016 | 09:07 AM
redtan's Avatar
Unless all the internals of those are completely destoryed, that is an awesome deal. Even if it's not running or needs work, the parts separately are worth more than that. If the engine turns over by hand and you can spin the transmission without hearing any noises you better jump on that.
Old Mar 3, 2016 | 09:47 AM
kainedogg's Avatar
In for the end result.
Old Mar 4, 2016 | 05:22 AM
redbird555's Avatar
Just to correct this for anyone looking in the future. The ls7 never cam with an auto and still doesnt, the only vehicles it came in were a c6z and new z28. The c7 uses the new generation of lt engines.
But ya op tahts a screaming deal for an ls7
Old Mar 4, 2016 | 08:40 AM
Rudy72's Avatar
Default Good info
Exactly right, wasn't thinking about the new engine package, just that they have a new trans in automatic for the C7..
Old Mar 11, 2016 | 01:57 PM
So I found out it wasn't an LS7, it's a LS2 supposedly in good condition. The guy wants $3000 for it.
Old Mar 11, 2016 | 02:31 PM
KW Baraka's Avatar
Puff, puff, pass.......puff, puff, pass.........
KW
Old Mar 11, 2016 | 02:53 PM
Zmg00camaross's Avatar
The old it's a ls7 but it's really a ls2 trick!
Old Mar 11, 2016 | 03:29 PM
Lmmfao!
Old Mar 11, 2016 | 03:30 PM
What's a good price for that engine, complete motor with wiring harness?
Old Mar 12, 2016 | 11:47 AM
blk00ss's Avatar
$1200
Old Mar 13, 2016 | 08:25 AM
redtan's Avatar
That's still not a bad price depending on miles and condition.
A complete LS2 with heads intake accessories is easily in the 1500-2000 range. The transmission depending on what is is can be anywhere from 5-1000 and the harness is a couple hundro also.
Old Mar 14, 2016 | 03:21 AM
Kamaro's Avatar
$2500 for a engine and trans in a good condition, supposedly LS2 + T56, is a very good price, added it has all the wiring and ecu is a big plus.
Old Apr 25, 2016 | 03:30 PM
jamescallowa's Avatar
Sounds like a pretty good deal. I have an LS7 and I didn't have much time so I let Engine World Inc in Houston rebuild it for me. They actually import JDM engines but they also rebuild LS motors big time. Here is their website http://www.bestjapaneseengines.com/
