Name that sound!
Old Apr 10, 2016 | 06:30 PM
jlwdvm's Avatar
Default Name that sound!
My Texas Speed 570 horse LS3 was finally started. After I warmed it up to temp for the first time the steam vent hose came off at the valley and spewed out some coolent (distilled H20 with Joe Gibbs additive). I got a better clamp on it to solve that problem. Days later I noticed a chirping/squelling sound that was there at idle and got much worse if rpm's climbed. I cleaned the belt with Dawn twice and the pulleys and idlers with alcohol 1st then Dawn. Everything was allowed to dry....the sound persists! I used a screw driver and my ear to listed to whatever I could to see if I could isolate the noise...nothing. All of the pulleys and idlers spin freely by hand with no noise. Thoughts? the motor has zero miles on it...just garage run time.
A video of the noise:
Old Apr 11, 2016 | 01:00 AM
ls1 1990 VN's Avatar
If it's none of the idler pulleys, disconnect the pcv valve & try again
Old Apr 11, 2016 | 06:48 AM
jlwdvm's Avatar
Forgot to mention that I pulled the belt and ran the motor for a short period of time to verify that the noise was gone...and it was.
Old Apr 11, 2016 | 07:27 AM
L92 OLDS's Avatar
I had a similar situation and it was the alternator.
